  • Not starting
    Posted by Peter on May 23, 2013 at 8:03 am
    Gen was not starting very well mine has brain on side of gen it would flash code had to go out side and reset it there are two plugs with wires going into them that plug into ECU took wires out of plugs put spade connectors on them it works great now those plugs go bad inside u can not see it though works good now the code would flash low oil pressure but that was not true it was not reading it right my gen is power tech 17.5
    Archived replied 12 years, 2 months ago 11 Members · 16 Replies
  • 16 Replies
    May 23, 2013 at 12:21 pm
    Hi Peter, I have the same gen set.
    When mine was starting rough I noticed a very small amount of fuel around the
    injectors. I replaced the o-rings, one of which was really “thinned
    out” and all was well. I’d check the battery connections too while you’re
    at it. These power techs are bullet proof, recently I ran mine for 5 days straight
    without and problems.
    Fred
    May 23, 2013 at 1:04 pm
    Thanks Fred mine was the plugs that went into ECU when we did that now starts on first go no more cranking twice power tech said its the plugs and to put spade terminal on them plug each wire onto spade terminal on ECU board
    May 23, 2013 at 1:13 pm
    I’m glad you figured it out and she’s up and running. What’s a “spade terminal”? I’m not familiar with that.
    May 23, 2013 at 6:15 pm
    the ECU has male ends on it flat the ones I put on wires are the female they push together they have to the ones with the cover over them to keep them from touching one another
    May 23, 2013 at 8:45 pm
    Peter,
    Did you replace existing spades or did you replace what was on it with spades?
    May 24, 2013 at 4:54 am
    The male spades are on ECU we took off plug that wires went into and put insulated female spades on and pluged them into ecu if it still does not work right it’s the ECU board
  • Glenn
    September 6, 2014 at 2:33 pm
    Red I had the same problem a few months ago. I had to replace the fuel pump which is no biggie. You can buy a replacement at any Nampa Auto Parts store.
    September 6, 2014 at 2:38 pm
    Thanks Sid, I wasnt sure because when things are running well one tends to not pay attention to what causes what noise. I thought that clicking was the fuel pump but wasnt sure. Off to Napa we go.
  • jack
    September 6, 2014 at 2:44 pm
    Certain generators, one a 20KW Kohler of an older vintage had an issue with fuel pumps. After a while it wasn’t delivering the necessary volume to handle the loads. I was shocked at the cost of the replacment which was around $360 and it had to come from a Kohler dealer.
    My current vintage 20KW Kohler has a different fuel pump and if I am not mistaken it is available at NAPA.
    I carried a spare of the first one, and once I did that of course it never quit again.
    September 6, 2014 at 3:04 pm
    Thanks Jon ,appreciate the input. maybe i will put the old pump in the new box and try to fool the generator gods. Naw that probably wont work. Im just not lucky like that.
  • Chris
    September 6, 2014 at 5:43 pm
    Red, did that fix your problem?
  • Ken
    September 6, 2014 at 8:33 pm
    Hey Red…Semper Fi….have a good time
  • gary
    September 7, 2014 at 7:57 am
    Red,
    Assume you have more than a 1/4 tank of fuel, correct? And all fluids topped off..
    September 7, 2014 at 3:39 pm
    Havent gotten to it yet sid Im at a reunion with guys I was in Nam with. Will get to it tomorrow I hope
    September 7, 2014 at 3:40 pm
    Yes I got plenty of fueln and all fluids are full also but thanks for the reminder anyway. Say hi to the boss for us
