  • No power to my thermostat
    Posted by Tony on November 29, 2021 at 2:43 pm
    My Vantare’s thermostat controls the bus heat and the central air. I am getting NO power to the thermostat this means no heat control though I am getting full heat no control from the Aqua hot and no central air out of the RVAC. Any body have any idea what the problem may be??? I have checked fuses and breakers
    Bill replied 4 years, 4 months ago 7 Members · 6 Replies
    December 4, 2021 at 11:37 am
    December 5, 2021 at 10:10 am
    I don’t know about that system, But I have DometicAC’s and a 5 button Dometicthermostat. Thermostat gets it’s 12v power from the communication cable (Phone cable) at the back side, and mine goes to #1 AC to circuit board then it daises to #2 then#3. But anyways after years of corrosion you can loose power or communication. Pull the plug out of thermostat a couple of times and at AC and see if that helps. Also AC unit gets 120v to run the AC and it also gets 12v to run it’s controls (thermostat)
  • Jon
    December 5, 2021 at 10:21 am
    Tony:
    Not sure about this, but I think there is a fuse on the control board in the basement unit that provides power to the thermostat.
    Chuck
  • Tom
    July 17, 2022 at 4:21 pm
    Do you know where the thermostat gets its power?
    July 17, 2022 at 4:54 pm
    On my bus the power to the thermostats come thru the telephone cable from the Control Board on the AC unit.
