  • No Heat Up Front
    Posted by Davy on December 14, 2012 at 9:51 am
    I replaced the control box in the aqua hot the end of November. I discussed that HERE. I put it in, made sure it cycled off and on and then had to leave the bus for two weeks. I left the thermostats set to come on and instructions for my dad to turn the aqua hot on if the temps went down to a certain level. The weather was nice while we were gone so he did not turn it on.
    When we arrived home the low was about 20 that first night so we turned it on. We have electric toe kick heaters and heat strips in the roof airs as well so we do not have to have the diesel heat in the living areas. I run it mostly to heat the plumbing bay and it does get it toasty inside real quick and the other heat sources can maintain from there.
    I have two heat exchangers up front controlled by one thermostat behind the drivers seat and two heat exchangers in the back contolled by a thermostat by the bed. The ones in the back work perfectly and the ones in the front blow cold air.
    I have not taken the cover off the aqua hot to examine anything yet. I know each zone has a circulation pump and I can feel if the one for the front is kicking on or not once I get down there. I thought I would ask for tips here before I crawled in the bay.
    Any chance my new control box is causing this? My dad repaired the relay that was burnt in my old control box so I am tempted to put it back in and see if that solves the problem. I know the front zone was working during a cold snap in Oklahoma in October or November.
    Any other ideas or things to check are appreciated.
    DKO
    David replied 13 years, 9 months ago 2 Members · 1 Reply
  • 1 Reply
  • David
    December 14, 2012 at 6:54 pm
    Rick,
    I don’t think there is any function in the cotrol box for the heat exchanger pumps. My pumps are controlled with relays mounted on the outside of the Aqua Hot box. You can confirm this by just turning on the heat at your thermostats, the pumps will run, your heat exchanger fans will run and the Aqua Hot doesn’t have to be turned on.
    I use the furnace function most of the time without the diesel on and use the hot water for heat. This worlks fine in cool temps, but if it gets real cold, the diesel is the only way to go.
    You can feel the motors running and I had one that got stuck and after rapping it with a screw driver handle, away it went. They need to be run often. Assuming your thermostat is calling for heat, check the pump wiring for current, then work back upstream to the relay.
