  • No Forward Motion!!!
    Posted by Hector on October 18, 2012 at 6:33 am
    No Forward Motion.
    I had a failure in my Allison transmission ECU! Yikes!!
    The symptoms were that the transmission would not shift into
    forward or reverse. Instead of the
    normal two digits being indicated, only the right hand digit would show and the
    shifter would beep 14 times each time the key was turned on??.
    It happened when I was attempting to pull forward after
    fueling at a Pilot fuel stop on IH-69, north of ,
    . We blocked the fuel island for several hours
    until the Allison technician arrived. He
    placed a test ECU unit in and I was able to move to a parking spot in the truck
    parking lot. There is no way to bypass
    or manually place the transmission in gear, according to the Allison tech. The Allison transmission ECU has to get it status
    from the engine computer
    before it will allow a transmission gear shift.
    After the ECU was replaced and software uploaded, all was OK again.
    This is one of those things that no amount of preventative maintenance can manage.
    Comments.
    If the coach does not move when you place the transmission
    selector in gear, you have a 45,000 pound chunk of stainless and iron. This will most certainly bring a very
    desperate feeling, I can attest. We
    spent the night in a Pilot truck parking lot and was on our way by the next day. Two service trips later (one at and the second to bring the new ECU at the next day), 85 miles drive from each way to our location, a new Allison ECU and
    of course $3,100.00 cost. Now that I
    look at it, it was part of the cost of ownership. After traveling for 10 years, I have had two
    occasions where my motor home was disabled.
    This was one of them.
    We were held up for 24 hours until repairs could be
    completed, then on our way.
    The ECU is located in the pneumatic compartment under the
    drivers seat. It is an aluminum box with
    a couple of cables plugged into it. A
    couple of items to remember, if only one digit (the right hand side), the
    shifter has identified a fault in the ECU and will not allow any transmission
    action. Second, I asked the Allison tech
    about low temperature issues that would prevent the transmission from
    shifting. He stated that two low
    temperatures exist in the Allison ECU.
    At minus 20 degrees, the transmission will not shift above second gear,
    until the oil heats up. At minus 50
    degrees the transmission will not shift into drive or reverse until the
    transmission oil heats above the stated temperature. Hell, I’m ,
    if we ever see any minus degree temperatures on the thermometer, we stay inside
    where it is warm……..
    FYI
    Hector
    Archived replied 14 years, 1 month ago 3 Members · 3 Replies
  • JIM
    October 18, 2012 at 7:21 am
    Glad you are back on the road.
    There is a second condition that will prevent any transmission from going into gear. That is an RPM above idle. On my coach I also need to have my foot on the brake. The point is that like the suspension our coaches continue to evolve and there are more and more conditions that have to be satisfied before we can engage D or R. Folks with slides also have conditions which must be met before the transmission can be shifted out of neutral.
    October 18, 2012 at 9:50 am
    Hector, thanks for your story. Wondering did Pilot attempt to make you get a tow out of the fuel dock?
    JIM
    October 18, 2012 at 7:43 pm
    The Pilot I was having the problem at did not seemed to be concerned. They sent a maintenance guy out to block the lane with a plastic caution barrel. I guess they have seen their share of broke down trucks.
    Hector
