  • No Cold Water
    Posted by al on August 7, 2020 at 11:25 am
    Hello , I seem to have a issue with a mixing valve most likely . I have only hot water . When this happened a month or so back i thought that maybe the ambient high tems along with using the aqua hot was the issue . Well that is not the case now . We are parked in Sd with only the elect element on .
    So my question is can someone direct me to where I will find the mixing valve and what it looks like ? Thank you in advance .
    cal replied 6 years, 2 months ago 4 Members · 4 Replies
  • cal
    August 7, 2020 at 11:40 am
    All faucets or just the shower?
    August 7, 2020 at 12:05 pm
    All Tim , shower,all 3 sinks .
  • al
    August 7, 2020 at 12:41 pm
    Al check faucet in bays or hand held shower in bay make sure all off, if valves are on and hand held is off hot and cold will mix or if washing machine has a issue it could mix. if you have a long hose outside going to bus it could be hot for a while.
  • Billy
    August 7, 2020 at 1:36 pm
    Art, Just went out to check and it is as needed . Faucet and hand held are both off. The only change I have made was to what i saw as a cut off valve from street water to tank. I also noticed the Headhunter pump was hot . The hose leaving the pump was also hot ? But with the pump off all lines were hot even the filtered water line . The water hose to coach is cold and only 10 feet away . Thank you for the ideas .
