  • Posted by Dale on July 18, 2014 at 8:04 pm
    let’s try out this section…
    I’m at a music festival in Michigan and ready to go back to Nashville. I drove up 500 miles this morning batteries charging good. Started once to back into a new spot since I’ve been here today. Time to leave and nothing… No gauges when key is turned on. No 24v lights to get up the stairs. I’ve been on shore power all say but that should have nothing to do with it…
    Any ideas? We would love to go home! haha
    If anyone has any ideas, I can be reached at 661-809-2463. Thanks.
    Archived replied 12 years, 3 months ago 2 Members · 2 Replies
    July 18, 2014 at 9:26 pm
    Have you checked the easy stuff?
    The breakers in the engine area next to the batteries?
    The breakers in the front electric compartment under the drivers window?
    Try cycling the rear / front run switch back and forth about 10 times, then leave in in the front postion and try again.
    If that doesn’t work, try starting from the rearr with the swicth in the rear position.
    My guess is that a circuit breaker is tripped since you don’t have lights in the step well.
    July 19, 2014 at 2:58 am
    Thanks for the input. Got it figured out. The batteries were actually dead. I had Eagle Nest go over my bus before my trip to North Dakota last week. The figured out my bus A/C issues. It was actually just missing some relays. So apparently, now there is another issue. When you cut the A/C off, the condenser fans keep running. So I,was plugged in on shore power today and didn’t realize the fan was running. I just thought the noise was the basement air. So the fans ran all day and ran the batteries down. A quick jump and we were back on the road!
