  • Need your help on my 50 amp hookup.
    Posted by Harry on February 21, 2020 at 7:52 pm
    Hi guys,
    My 50 amp plugin on my bus is in the water bay on a metal plate (right side of the bay) as shown on the picture below. The power cord comes through the floor and must immediately be bent towards the plate. The problem is the plate has come loose on the bottom, making hookup a challenge to say the least. Since the plate is not secure at the bottom I have to put my hand behind the plate to keep it from moving away from me. Without gloves it’s a good way to tare your hands to pieces, something I’ve done more than once. Do you have any ideas of how I could secure the plate in place preventing it from moving?
    I’ve got to figure something out before the plate breaks off from the top and then I’m really in a pickle. Thanks for any thoughts you have…
    Harry
    Archived replied 6 years, 8 months ago 10 Members · 15 Replies
  • 15 Replies
    February 21, 2020 at 9:20 pm
    Would have been better if you moved that raggedy looking hose out of the way for the picture Harry ole boy. You can make L brackets to stiffen it up. Oops, at your age I shouldn’t have said stiffen.
    February 21, 2020 at 9:57 pm
    Hi Tom, I didn’t think of L brackets but I’d need them in both corners right? Because I have to keep the bracket from coming forward or going backwards. And I don’t know how I’d get behind the plate, especially on the right hand side? Maybe a spot weld? Here again, putting something on the front is relatively easy because the plate goes down to the floor. Again, the problem is getting something behind it. it’s a poor spot to locate a plug-in but that’s what I have to work with.
    Harry
    February 21, 2020 at 11:52 pm
    If it were mine, I would install a 50 amp plug, Marinco # 6373EL, on the outside of the bus, somewhere convenient. Liberty put 2 extra 50 amp plugs on the outside of my bus, one on each side, down low, just forward of the drive axle.
  • Harry
    February 22, 2020 at 10:27 am
    Hi Don, I have a feeling that may be the answer. Probably an expensive answer, but the answer non the less. Thanks for your feedback. If anyone else has an idea I’d like to hear it?
    Harry
  • Dan
    February 22, 2020 at 12:40 pm
    Harry. Sent you a photo of our former Beaver Bus 34. It gad external shore connection by Marinco
  • Craig
    February 22, 2020 at 2:02 pm
    Here’s what they look like on my old Liberty. Under one of these caps is where the rose pedals are uploaded.
    They are available on amazon, the 50amp Marinco 6373EL input plug, not the rose pedals. Fairies bring the rose pedals during the night.
    February 22, 2020 at 2:55 pm
    Any ideas where to get that done guys?
    February 22, 2020 at 5:25 pm
    Harry, Why would you take it anywhere besides ETLC? If i live 70 miles from there they would probably have to get a restraining order to keep me away.
    February 22, 2020 at 6:43 pm
    You’re right of course Jeff, as soon as I made the post I thought “well dah”!
  • Mark
    February 22, 2020 at 9:08 pm
    Harry…we need to talk about this before the Liberty police show up.
  • Craig
    February 23, 2020 at 1:16 am
    Al: are those rusty Phillips screws not stainless steel?
    February 23, 2020 at 10:56 am
    Harry, How about a temporary fix by adding a 50amp adapter (pigtail) for an easier hook up.
  • George
    February 23, 2020 at 4:33 pm
    Good idea on the pigtail….
    February 24, 2020 at 8:11 am
    The pigtail was actually the first thing I tried. The problem is there is little room to navigate with something as ridged as a pigtail. I was also unable to close the cabinet door and without it 80% closed I can’t close the bay door. It may be possible if I take the cabinet door off, I’ll have to check it and see.
    Harry
    February 24, 2020 at 10:16 pm
    Most of the receptacles are made by Hubbell, they sell to other companies which are brand labeled. Maybe you can use the existing receptacle as the junction and install an external fitting.
    https://hubbell.dcatalog.com/v/Hubbell-Marine-Catalog/?page=10
