Need Rv drivers for phoenix Arizonia and nj
Posted by gary on November 18, 2021 at 10:24 amI finally bought a coach Prevost Marathon 2001 H3 double slide thank you for everyone’s advice. Right now I need RV drivers for the Phoenix Arizona area and New Jersey also. Does anyone have advice or suggestions
thank you Dr Gary Goya12@aol.com.
201-663-0935Chad replied 4 years, 10 months ago 11 Members · 12 Replies -
Here’s free advice. The selection of a driver is going to be critical because you not only want someone qualified to drive, you want that individual to know and understand your coach conversion. You need assurance he will do an extensive pre-trip inspection of both the coach and conversion because once on the road your exposure to unplanned repair costs can get deep into your wallet.
I would also expect the driver to protect the coach and not use it for a party for a hundred of his closest pot smoking friends.
Personally I would fly to AZ and either drive it home myself with the driver as a teacher or as someone you personally supervise. You need the experience, the training, and the opportunity to get to know the coach which will answer almost all the questions you have asked.
Gary,
Sent you a text with suggestions. Please let me know if you don’t get it.
Thank you for the advice yes I agree I need an experienced driver with RVs that has been on the road for several years and it’s very important to have a back up driver
thanks Dr Gary
Gboya12 @aol.com
201-663-0935
Maybe https://gossrv.com/landing-page-driver/
Or call some of the dealers in those areas who sell & service mostly Prevost. Check the advertiser on this forum
DO NOT ASSUME AN RV DRIVER UNDERSTANDS A PREVOST CONVERSION. An RV compared to a Prevost conversion is like comparing a pickup truck to a Mack truck.
You need someone who not only knows the Prevost chassis, but also knows your specific converter. Look how many questions are on this forum from owners who do not know what the dash lights mean, how to operate the house systems like heat and A/C or even how to operate the slides, both normally and manually.
This goes back a few years Jacksonville had a show and driver quote parked bus BUT never set parking brake you quessed it rolled into loading dock. Just because you can make it go forward doesn’t make you a driver.
Your hiring a driver to pilot your new bus ? Where on earth do you expect to find a reliable / experienced driver to handle a 50,000 lb Prevost with a commericial D/L, and a good driving record ?
This whole thing is a train wreck.
May I suggest calling some of the conversion coach companies and ask them if they have recommendations? I have personally talked with a retired FL state trooper who has been transporting coaches for Liberty Coach, for the last 9 years… I helped him when he had a tire issue along the way of a transport from FL to MN… you can find him through Liberty Coach; alternatively, I can reach out to him directly and ask if he’s interested.
Pat has offered some good advice above.
My concerns apart from having a qualified driver who knows both the chassis and conversion, it is important that regulations are followed.
For example, if the driver is compensated he must have a CDL, Class B. Even if he is not compensated the laws relating to the state the coach is registered in have to be followed. In other words if it is registered and licensed in TX, a Class B CDL is required. It is is registered in TN only a regular driver license is required.
All of this is unimportant as long as the trip is uneventful. But if the driver is in an accident, especially a personal injury accident then it is likely the police will be all over the coach, driver etc. verifying compliance with the laws.
Leesburg, FL -
This statement is not true.
If you are legal in the state where your driver’s license is issued you are good to drive anything your license allows in your state, regardless of where it is registered.
The CDL requirement is a sticky issue, it may or may not require a CDL, depending on the job description. If the vehicle is paid for movement, ie commercial trucking, a CDL is required. If driving is a part of your job, not the only thing you do a CDL may not be required. Example, you are your employers assistant and one of your many duties is driving, a CDL is not required. It is not cut and dried.
Another option would be look for professional tour bus drivers.
Bill
I found A professional quality transporter with CDL license real pro and owns his own prevost marathon. 20 years experience I’ll continue to look for back of drivers like him. Thanks for your help
1984 96" with 8V92TA
(remodeled Liberty Coach)
Greenwood, MO
