  • Need help level low switch
    Posted by Bob on April 26, 2012 at 8:26 pm
    As many know I’m rebuilding a salvage shell. I have the rotary switch level low select – no face plate to tell which position is which. I know I can do trial and error. But can anyone give me a quick hint? there is a metal strip on one side. Bob
    Bob replied 14 years, 6 months ago 3 Members · 4 Replies
    April 27, 2012 at 12:23 am
    Bob mine is a “91 with a rotor knob, pointing to the rear is the drive position, left is left and right is right side and to the front is front air bags. Greg
    April 27, 2012 at 8:16 am
    I have a 98 and mine is just like Greg’s
    April 27, 2012 at 9:42 am
    Question is mine is laying loose. not mounted with no top on it just switch. Pannel it mounts to is missing. knob is there and switch,–no cover plate. I can set positions and see which one lets operates in drive mode and go from there. Bob
    April 27, 2012 at 12:28 pm
    Whatever switch position energizes the center solenoid valve is the drive position. Just hook your volt meter to that valve’s input and when you see 24 volts the switch is in the drive position and all other positions are then as described above.
