  • NAPA discount card
    Posted by AL on January 3, 2017 at 9:26 pm
    PC members….
    Check your NAPA discount card as many have expired with the new year. Home page contains the link highlighted under ……..PC members discounts
    One of my projects was replacement of four (4) starting batteries. Savings were around $50 per battery using the NAPA-AITA card.
    Napa man asked to see my card as they need the code number on the back. If you have any questions about this extremely successful PC program….Please post.
    Archived replied 9 years, 5 months ago 19 Members · 34 Replies
  • 34 Replies
  • Bryan
    January 4, 2017 at 11:02 am
    I have a dumb question. Can the Michelin Tire Program and or NAPA be used any vehicle or just for Coaches? Thanks
  • Doug
    January 4, 2017 at 11:07 am
    The NAPA card works for anything you wish to buy for any vehicle at participating NAPA stores. The Michelin discount seems to be limited to RV or bus sized tires, but I have never tested it.
    January 4, 2017 at 11:56 am
    Michelin program can be used for other tires also. Geo.
  • Michael
    January 4, 2017 at 1:50 pm
    I saved over $60 on two chassis batteries this weekend with the NAPA card. Sweet! I received a replacement card in the mail a few months ago. New expiration is 2019.
    January 4, 2017 at 5:01 pm
    Al,
    Which batteries did you get at NAPA? I may need to replace mine. I have a new AITA/NAPA card with 2019 expiration.
    Thanks for setting this account up!
    Doug
    January 4, 2017 at 5:44 pm
    Our card expires 12/31/19 thanks Al
    January 4, 2017 at 5:56 pm
    Ours also expires 12/31/2019.
    January 4, 2017 at 8:46 pm
    Doug, If you have this type of top post, threaded post your choices will be ….
    NAPA part number…..7231 w/ 650 cca cold crank amps
    7238 w/ 760 cca
    7234 w/ 1125 cca
    My choice was 7234 w/ 1125 cca also having 195 reserve amps rating.
    If you order batteries here is my suggestion….Order them a day ahead of time and ask that they fill your order with 4 fresh batteries with the same date codes. This request should be handled without any excuses. If you get push back ask to speak to the manager.
    January 5, 2017 at 12:45 am
    Thanks AL. I’ll let you know the results. Much appreciate your response. I think I killed my chassis batts!
    Doug
    January 5, 2017 at 9:51 am
    Al,
    Ditto what the others are saying on the expiration date. I think at the last renewal the card date went to 12/31/2019.
    Happy/Healthy and prosperous New Year. Thanks for the NAPA card. I’ve used it for all my vehicle related purchases. My counter guys here in the South are very accommodating with special orders on items not normally in stock. Oh yes, typically overnight from a warehouse somewhere in NC or SC.
    January 5, 2017 at 12:31 pm
    I’m trying to fill out the form to get my first set of Napa cards and it won’t go through unless I list a company name and company address.
    Will it not just take an individual name?
    Thanks,
    On edit: (from below)…. Thank you Jon!
    January 5, 2017 at 12:39 pm
    Use the name Prevost Community. That is how we are listed.
    January 5, 2017 at 10:34 pm
    Doug wrote: I’ll let you know the results. Much appreciate your response. I think I killed my chassis batts!
    Doug: Before you go out and spend money on new chassis batteries, jump over to the Electrical section and tell us about your problem, include the age of your batteries if known.
  • steve
    January 6, 2017 at 6:09 am
    Doug,
    Dick has a good suggestion. Before I replaced any batteries that failed prematurely I would find the reason for the failure. If I were to guess my first thought would be you were using the chassis battery charger a lot, if not continuously.
  • Reagan
    January 17, 2017 at 5:54 pm
    Thanks Al
Page 1 of 3
