My 91 Beaver Coach Problems II The Resurrection!
Mike replied 9 years, 5 months ago 41 Members · 141 Replies
Hi Jon, I don’t know at this point what they plan to charge me. The only charge I know for sure is the replacement/change of the air filter housing for $1,1000.One thing i never gave a thought to is fighting things (if I feel the Clarke charges is obnoxious ) through my credit card company. My bank is USAA and their terrific. But are you saying that USAA will debate the charge with Clarke even after I signed for their services?
Harry
Air filter or fuel filter? There is a difference and for the life of me I cannot understand how they get that much money.
The fuel filter, which you said it was before) is fully serviceable and if anything all that is required is a new element and the bowl to be cleaned.
Hi Jon and Yes, they showed me a jello like substance in the fuel filter. They went on to say it was almost impossible to get all the jello like substance out of the housing holding the filter. They told me it could well cost more to have them clean the housing then replace it. It was their recommendation to replace the housing with the current style of Prevost fuel housing and filter. I went along with their recommendation.Harry
Using strong strength Dawn and/or ZEP Foaming Degreaser couldn’t have cleaned it?
Sounds like on the filter, they had a guy that didn’t want to get dirty. They are made, even if you have to remove, clean out, and put back on which I haven’t ever heard of doing if it’s a racor. Use to run them on the 3 and 4-53 detroit powerunits at old job many moons ago. They got nasty from drilling rig fuel we used to steal to run them and fueling from dirty 5 gallon buckets with who knows what inside them. If gel was in bottom of filter it was in fuel lines also. Hope for the best Harry and good luck from Texas.
Harry, your thread #3 is locked???
If your bus has the below pictured fuel/water separator/filter, Racor 1000FG, it is easily cleanable & rebuild able. Here are pictures from when I did it on our bus less than 2 yrs ago. I removed, cleaned, and rebuilt it with Racor seal kit RK 11-1404 and a Fleetgaurd element# FS20203(30 micron) and its seal kit#21139. Total cost $55. Took me(non-pro) about 2 hrs.
Good post and pictures Don.
That filter part number is an excellent assembly being used on 1000s of boats and equipment around the world. It’s as you say easy to clean and rebuild. Many boats use 2 for each engine with shut off and by-pass valves.
When engines show signs of fuel starvation simply switch to a ready to go filters. This is a valuable filter assembly and a shame what happened.
I carried the rebuild kits in stock for my NAPA customers. Filter elements were very reasonable priced.
Thank you Don, And yes, that’s what they replaced! I also noticed you have a plate above your battery bank and I’ve net seen that before? What’s the purpose of it, something above that could drop down on the posts?
Harry
I think that chassis battery cover is standard equipment. My ’99 has it as well. Held down by three bolts. Any adequately sized piece of plastic will do.
Gerald
My 87 did not have the cover but my 97 did so somewhere in between Prevost started installing them. It gets to be a big deal if the supports for the cover are not there so either do without, or fabricate some means to support and secure the cover. It should be a heavy plastic or rubber like a truck flap and its only purpose I can see is to prevent accidental arcing if you should drop a tool onto the batteries. The cover doesn’t do anything else I can see.
You need that cover, one wrong move dropping a wrench or anything metal is going to cause a bad day.
I was curious and thought that must be the case. Mine is like your 89 Jon, no top protection, just two rods secured by four large wing nuts. -
Hi Dick,I’m picking up my bus from Clarke first thing tomorrow morning and I’ll be off to ETLC. I’m very disappointed with Clarke and not because they didn’t fix the problem. It’s from their lack of communication… In 8 days they called me twice and it was on the same day. If I didn’t call them I’d have learned nothing of what they were doing with my bus! They gave me the broad diagnostic conversation but it became obvious it was a cover for “man I just don’t know”!
When I talked with them today and told them I was picking up my coach in the morning. They said the speed situation is fixed but not the cruise and Jake brake. They said they chased those two issues down to a positive ground situation but was unsure where?
I’ll believe the speed over 55 issue when I see it. Not that I think they lied to me, I’ve just seen it happen a few times that it would run at 65 but not for long, may five miles or so. So If they didn’t run it enough it may not be fixed. I’ll know when I’m running between Clarke and ETLC if it’s fixed or not.
Im learning and I’ll be curious what my learning is going to cost? Can anyone say ouch!
Harry
If the speed is resolved I would press very hard to find out what the cause was. Even if they do not know specifically which of their “repairs” cured the problem, at least knowing all that was done is going to be helpful if it occurs again to you or someone else.
The Jakes just require some relatively simple checks to isolate the possible cause. On my 87 coach I had the solenoids fail and a simple check with jumpers revealed that problem. If they are OK it can be verified and shift the focus to other potential issues.
