  • Mud Flap repacement
    Posted by gary on June 14, 2013 at 12:51 pm
    Was checking tires on my walk around the last day out thursday and noticed my mud flap on the port side behind the tag was tearing so I removed it just cut it off. Question I understand this is a Prevost item and the stainless was added by Liberty where can I buy the flap I cn put the stainless on can I order it online and how do I do that, Thanks in advance feels good to be back on the road! Gary
    Kevin replied 13 years, 3 months ago 6 Members · 6 Replies
    June 14, 2013 at 2:39 pm
    Gary,
    You can buy mud flaps a lot of places and then cut one to size, drill the required holes and you should be OK.
    I suspect buying through a converter or Prevost might get a little pricey.
    June 14, 2013 at 3:17 pm
    Having purchased a pair through Prevost, I can attest that you suspect correctly….
  • JIM
    June 14, 2013 at 6:57 pm
    Any truckstop or truck parts supply will have mud flaps Gary, then just cut to fit as Jon suggested. I have a spare in my garage for just that occassion.
  • Thomas
    June 15, 2013 at 8:09 am
    I checked on eBay and searching “prevost parts”
    there is a pair of used on now with bracket….. check it out as a bargain..
    rgds,
    June 15, 2013 at 8:13 am
    eBay # is 200932584525
    shows XLII a pair of rear flaps with frames
    hope this helps.
  • Kevin
    June 15, 2013 at 10:14 am
    If you have a NAPA store near you most have a stock of mud flaps. Many sizes and thickness.
    In my case I purchased the plain none logo and used the old for size and hole locations.
    Cutting to match I used an old tin snips which left a clean shape line.
    NAPA is very reasonable on this item.
