  • More Bad Part Numbers Later Model XLII
    Posted by Archived on May 15, 2017 at 12:13 pm
    I only know this relates to my XLII, but it could affect all XLII coaches after the 2003 chassis model year.
    According to Prevost parts the tag axle part number for my 2005 chassis air bag should be 630239. That is not the right part even though the information Prevost parts is working with says it should be after 2003.
    The real part number is 630151, and that is the tag axle part number up to 2003 according to parts. Be aware if you are doing your own air bag replacement or having a replacement done at a shop that if you get the wrong air bags you are going to have a delay in the completion of the job and what should be a one day job may run longer if the shop does not stock 630151 air bags.
    What is frustrating to me is my bus now sits in the garage, taken apart and not ready for completion while I await the correct air bags. I asked if the parts folks can get this error fixed and the answer is they will only tell the “publications” people of the error. If it goes back to the origin of the error it is doubtful so unless someone raises hell this problem will be with us for a long time. This one comes under the heading of “pain in the ass” because once the shop has the wrong air bags and no correct air bags their option is to reassemble the bus with the old air bag or leave the coach apart until the correct air bag is delivered. That means you as owners might be sleeping in the coach inside some shop or you might be paying for the extra time and effort involved.
    For shops like ETLC they may have a bay tied up or they may end up with the coach outside, on stands in pieces awaiting the correct parts, but regardless of how it is handled the inconvenience is spread all around. Since Prevost doesn’t like to be corrected by peons like we PC members I hope those with some influence read this and can get the error corrected.
    In case anyone doubts that Prevost does not take us seriously keep in mind when engineering transposed 630259 and 630260 air bag part numbers a lot of conversion owners lost the ability to level their coaches using level low because the steers were getting the wrong air bags. That error went on for several years. A similar error was when the part numbers for the flexible couplings on the charge air cooler system were transposed cold spec couplings were installed on the hot side (and were blowing out) and hot spec couplings were called for on the cold side costing owners several hundred more dollars than necessary. In both cases things got a little hostile before needed changes were made so if you have an XLII and are going to get air bags replaced keep in mind you may need to verify you are going to get the right air bags.
    Archived replied 9 years, 6 months ago 1 Member · 0 Replies
