  • microwave replacement
    Posted by terry on September 6, 2020 at 9:27 pm
    HELP. in an older posting. i read of a micro convection a replacement unit for our 1999 marathon. anyone know of one. we would like to update ours. thanks
    PHILIP replied 6 years, 2 months ago 5 Members · 4 Replies
    September 7, 2020 at 7:14 am
    We replaced ours with a new convection unit several years ago. Get the make & model number off of your current micro & look on eBay. If you’re looking for a direct replacement, you should see something there. If you want another make/model, note the exterior dimensions of your current unit, which should be noted in the description on eBay. Then use that info to narrow your search. Mounting can be a challenge, so if you’re wanting to change make/model, pay attention to the mounting system for the one you have vs the one you want to install.
  • PHILIP
    September 7, 2020 at 9:02 am
    We replaced ours with another Sharp more up to date used same backing plate easy instale
    September 7, 2020 at 9:24 am
    We replaced the micro/conv oven in our ’08 Marathon XLII with the GE Advantium.almost a direct replacement with the exception of rerouting the power wire hole (not a big deal). Loved that oven with the exception of the LED clock not staying lit by design.
  • David
    September 7, 2020 at 11:37 pm
    Likely it’s easier to just replace with the same brand. A different brand might not install without modification. Also, the hinge at the door might not fit right in the cabinetry.
    Linda
