MICHELIN TIRES
This week I was in Greenville SC, the guest of Michelin Tires for purposes of learning about tires, how to care for them, things that will affect them, and how to get the most out of them. The training was intense and our days started at 6:30 and went until 8:30 or so in the evening. We got so much information jammed into our visit it was like drinking from a fire hose. Over the next few days or weeks I will pass along as much of the information as I can, either in the form of articles, links, or posts on the forum.
Over the years we have offered accurate advice and information such as taking tires out of service when they reach a certain age and the importance of the correct tire pressures. But there was so much additional information we learned it will be passed along as soon as I can get to work.
I will emphasize the two points mentioned above. Our tires are going to age out unless we wear them out which seems unlikely for most of us. They will not recommend the use of tires beyond 7 years. Our type of use especially is very hard on the tires because the compounds used to resist the aging process are not getting released when the coaches sit unused for longer periods and the appearance of the tire (lack of visible cracking) is not necessarily an indicator it is OK to keep on using them. This may seem like Michelin just wants to sell tires, but it is the only time during all of our sessions that they were not advocating for methods to get the most life out of the tires.
The second point worth mentioning is the importance of the correct tire pressures. Weigh the coach, go to the charts and inflate them to the pressure called for. If you over inflate it is far better than running with less pressure but they do not encourage over inflation because it changes the tire contact surface with the road and the tire contact surface affects wear, handling and performance. If you run under inflated the tires are going to heat up more and the biggest enemy of tires is heat. The heat is generated by the flexing of the steel bands within the tire and at some point the heat can affect the rubber, especially the inner liner, or can result in the steel bands breaking. Any tire that has been run below the required inflation pressure can fail catastrophically.
I will pass along more information as I can pull it together. I was so impressed with how Michelin builds their tires and maintains the consistency of production worldwide I will be using only Michelin tires on my coach in the future.
If you want to study independently or learn more details bookmark and go to this page:
http://www.michelintruck.com/reference-materials/manuals-bulletins-and-warranties/
