  • Michelin Tire and Wheel Swap
    Posted by steve on September 13, 2018 at 2:15 pm
    Live in Maryville,Tn not far from ETLC. If any one wants to talk swap of Michelin 365`s to 315`s wheels and tires I`m open. My XLII is slideless and don`t need extra weight carrying possibilities, etc. of 365`s. Tag tires and wheels are dated 2013 @ 4k miles on them. Fronts are 2013 wheels and tires are 2018 @ 50 miles. 423-902-1253.
    Chas replied 8 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • steve
    September 13, 2018 at 2:32 pm
    What are your axle weights Steve? Not the limits, but real weights. Also, I am sure you are aware when 365 wheels and tires were added they use different studs I believe.
  • joel
    September 13, 2018 at 2:59 pm
    Don`t have actual axle weights, but nothing has been added since original manufacture which had 315`s. Should probably run to Luv`s and get weights.
  • Roger
    September 13, 2018 at 3:45 pm
    You don’t have the real weights???????
    How do you know the correct air pressure for your tires?
    September 13, 2018 at 7:36 pm
    Not that easy, the 365’s are hub pilot so whoever did your conversion from 315’s to 365’s had to change out the studs. Someone else would have to answer the question if you go back to 315’s, do you have to change back the studs to stud pilot or can you mount a 315 on the existing hub pilot studs.
    Ya I know, who’s on first…..
    September 13, 2018 at 8:30 pm
    Great point Jon. I`m looking for axle weight printout I believe to of gotten for setting air pressures when first I first purchased. I have driven through THP weigh station on I-40 and recorded display. THP didn`t like me doing that , but no law against it as far as I know. You know that memory thing !
    I may drop this project. Seems too $$$ for the trouble if hub changeout is needed.
    September 15, 2018 at 11:46 pm
    Keep your wheels and just change the tires.
    September 16, 2018 at 6:06 am
    You should not put 315 tires on wheels for a 365. Every tire has a listed wheel size.
