  • Mascontrol Unit Leaking
    Posted by Archived on January 17, 2015 at 8:31 am
    I have a Mascontrol Pump Controller unit mounted on the AO Smith water pump for our Marathon that has started leaking around the diaphram cover. There are a series of screws holding it on but I am afraid to pull it off until I see if anyone else has had a similar experience. Perhaps there is an aging gasket causing the problem or even the diaphram itself. RainHarvest Systems outside Atlanta sells the entire unit new but that would require some pipe fitting work to replace it which I am hoping to avoid.
    AL replied 11 years, 9 months ago 5 Members · 4 Replies
  • Rick & Denise
    January 17, 2015 at 11:55 am
    I have a extra controller it is a rain master part number 4000633 that replaces mascontroler no plumbing changes call me if you need it at 580 695 7043 I have 2001 marathon it has ao smith pump with mascontroler rain master has same size inlet 1 inch and quater Thanks Busman
    January 17, 2015 at 1:24 pm
    Thanks Busman. I’ver got to wait until Monday to see if parts are available from that vendor. If not I will holler at you.
  • Marius
    January 17, 2015 at 4:40 pm
    January 19, 2015 at 8:04 pm
    I sent a text to that number. Did you get it?
