  • Marker lights
    Posted by Chip & Pam on December 28, 2014 at 1:25 pm
    back in June I replaced all the marker light bulbs with LEDs. The original prevost markers with LED bulbs. 6 months later, I am concerned about the aging seals on the markers. The roof top markers are the ones. Am talking about.
    I would like to replace all the lighting gaskets (seals). I can’t seem to find the right ones online, in July, while at prevost Jacksonville, I asked about the seals but they are not sold separately . So here is my question: do any of you know where I can get replacement gaskets?
    Archived replied 11 years, 10 months ago 5 Members · 6 Replies
  • Chris
    December 28, 2014 at 3:52 pm
    Is this the marker light ? Screw holes are 3 5/8 inch apart.
    December 28, 2014 at 4:35 pm
    Since LED lights have a significantly greater life than conventional lamps I would use a small bead of RTV silicone sealant around the clearance lights. I don’t really trust gaskets and the bead is not visible if you use the clear and smooth it out.
    December 28, 2014 at 7:36 pm
    Al
    those at the ones. Admin mentioned putting a silicon bead, that may be the only other option since I can’t find the gaskets.
    December 28, 2014 at 9:16 pm
    The gasket is available through TruckLite part number 97701 (gasket only)
    Complete marker lights are available from NAPA part # 25250R (red w/gasket)
    # 25250Y (yellow w/gasket)
    . These are the exact replacement for OEM with upgrade to 6 LED
    Available at NAPA list price $ 25.89 each.
    Using your PC – NAPA card, $ 14.75 each
    FWIW……Grote lighting is suppler for “clearance” lights used on Prevost in red and yellow replacement in LED.
    A call to Grote customer service learned there marker lights need some trimming for install and not available in
    Red lens.
    New TruckLite marker light in 6 LED. Note; wires due not have connectors, so you need to do your own reconnect. With factory plug in ends marker lights increase in cost.
    Surface mount replacement on left
    December 29, 2014 at 6:35 am
    Al
    thank you for the information. I really appreciate it. I will contact the supplier for the gaskets as I all ready have LED bulbs in.
    I love this forum!
    December 29, 2014 at 9:48 am
    Chip bring your bus on down to Indio,Ca and Big Al will install them for free!! I know how he loves to tinker here in the desert.
    Stagecoach driver
