  • Marathon Audio Noise
    Posted by Archived on October 12, 2014 at 11:48 am
    I’ve been chasing a problem with bad interference and load humming through all the coach TV’s and finally sorted it out. If you experience any of those problems, it might be the same as mine, the RF Modulator. All A/V in my Marathon go through this Modulator and it was bad. There is a new version that is identical and easily changed out. My 02 is pre Creston, so may be different.
    Larry & Diane replied 12 years, 1 month ago 3 Members · 2 Replies
    October 12, 2014 at 6:59 pm
    Tom, I replaced the same unit about 2 years ago. It was a little tricky programming it for the 100, 101, 102, etc channels but I’ve had no problems since. My coach is pre-Crestron. I’ve bought two replacement Phillips remotes on eBay and Marathon reprograms them as I’ve replaced various AV components over the years.
    October 12, 2014 at 7:50 pm
    Once I figured out the programming for 100, 102, 104 and 106, it was easy. The blink codes threw me off, couldn’t count fast enough.:)
