Marathon Air System vs. Prevost
I’ve attached a picture of my Marathon Aux shut-off valve & lines. When I was at Prevost, they said they Marathon tied into some of the Prevost side (look at the photo and the orange connections on the right are Marathon which they said were on the Prevost side). I thought this valve somehow totally separated the Marathon side from the Prevost side?
The Prevost guys also stated that their F/R brakes and Aux air lines are connected together and the gauges can go down together when the bus is shut-off; however, there is a pressure protection valve that automatically shuts-off the brakes from the Prevost Aux side at between 60psi-90-psi, depending on the bus.
For example, the leaking air line behind my dash, which is now fixed, was to the F/Brakes, but all three of my gauges leaked down at the same rate before the compressor kicked on at 105psi. Although the Aux leaks down in around 24-hours, the brakes have now held at around 75psi for several days (and should hold indefinitely according to other posts here).
All DOT Brake checks showed no PSI loss. Does this sound about right?
