  • Manually retract front privacy window shades?
    Posted by Chas on August 18, 2015 at 5:19 pm
    I thought I had seen it here somewhere but a search produced nothing.
    I have the drivers side motorized window privacy shade down and it doesnt want to go up (ye, I see the threads that Jeff has the motors, I’ll be there next month so one more item to add to the list). How can you manuall retract/roll them up so I can drive?
    This is on a 1998 Liberty XL. I am sure they used a standard setup for all their models as well as some other companies used the same electrical rolling mechanisms.
    Bryan replied 11 years, 1 month ago 6 Members · 8 Replies
  • 8 Replies
    August 19, 2015 at 10:10 am
    Hi Charles, I had a motor shade go out and got one from Liberty. They are pricey if you ask me. The motors are on line ebay etc if you look around and are about the same price as at Liberty. I had to manually roll up the shade until I replaced the motor.
    Fred
  • Andre
    August 19, 2015 at 10:48 am
    So how do you manually roll the shade up?
    August 19, 2015 at 1:27 pm
    When you say driver’s side, do you mean front or side privacy shade?
  • Bryan
    August 19, 2015 at 2:05 pm
    side window. But the motors on all the privacy shaded seem to be the same. Just different lenghts.
    Right now it doesn’t roll up or down. Even if I try to manuall move it.
    I am thinking the motor part is inserted into the tube that holds the shade. Can’t figure out how to get the tube off the motor either.
    I guess I could just roll up the shade from the bottom and “tie” it up to the tube with velcro straps. That way I can still use it until I get this repaired.
    But I am thinking there is a way to roll it up manually on the roller. Basically disengage the gears from the motor?
    August 19, 2015 at 8:18 pm
    If you roll it up try not to fold it as it will leave marks in it…On one end of the roller look and see if there is a plastic piece usually white on the end with the bracket. That piece will twist 1/4 turn and will allow that end of the roller to come out…
    August 19, 2015 at 8:39 pm
    Just remove the whole shade, like Jeff said, twist, unhook the wires and take it down.
    August 19, 2015 at 10:45 pm
    Thanks Jeff and Tom.
    I had figure out the getting it off the bracket, but the side with the motor has the wire running behind the window frame and has about an inch of play.
    I think for now I will simple roll it up form the bottom (not fold it, but roll) and velcro wrap that rolled up portion to the roller at the top.
  • Eric
    August 20, 2015 at 8:39 am
    Charles,
    Mine had mini plugs on the end for power. The wires may be inside the framing, but mine were all long enough to allow unhooking and had plenty of slack.
