Manual door drop
Again we are new to Marathon/Prevost. Can someone explain to me the function of the manual door drop on a Marathon. I see a push button, a pull lever and what looks like a pressure gauge. It appears that if your air door drop doesn’t work you can use this manual process to drop the door. But what about closing the drop door? Also, what do you do if you loose air to retract the sewer hose and power to retract the power cord. There appears to be no easy way to manually retract either of these items. How can you drive away if you can’t retract these?
