  • Maintenance Issues
    Posted by Tim on April 13, 2015 at 8:02 am
    I’ve read some different articles about having to replace the pneumatic seal around your slides and, replacing your Black/Grey water tank(s), depending on the Converter
    Should the pneumatic seal & black/grey water tanks be inspected at time of purchase and, should they be replaced at an interval or simply when they fail?
    Edward & Sandy replied 11 years, 7 months ago 2 Members · 1 Reply
  • 1 Reply
  • Edward & Sandy
    April 13, 2015 at 8:21 am
    The tanks in question are aluminum and aluminum will not last long in a plumbing system.
    The slide seals are a maintenance item. The only inspection I can think of that will not involve some disassembly of the coach slide is to verify the seals are holding pressure. Since a lot of coaches now have slides and we don’t see a lot of posts relating to slide seal replacement that means they have a relatively long life, or nobody is talking about it.
