  • maintaining air pump
    Posted by Jeff on July 14, 2020 at 1:05 pm
    Still trying to run out some auxillary air issues, I am being told that Prevost has what is called a “maintaining” air pump, and mine is not operating. If anyone is familiar with this please share any info that would be helpful. My repair shop says they cannot diagnose or repair this and that it is strictly a Prevost component.
    thanks,
    Dick replied 6 years, 3 months ago 6 Members · 6 Replies
    July 14, 2020 at 1:18 pm
    Auxiliary compressors are installed by the converters so if you can see or get at yours you can learn what brand, model and size you have.
    Perhaps some Featherlight owners can help here.
  • Deleted User
    Deleted User
    July 14, 2020 at 3:41 pm
    Mine on my Royal is about the size of a basketball and silver in color I believe. As Jon mentioned, converter installed, so I could be anywhere.
  • Jeff
    July 14, 2020 at 6:52 pm
    Fred, where’s yours on your Featherlite?
  • William
    July 15, 2020 at 12:03 am
    On my featherlite it’s located inside the generator hush box off to the side. Very easy to get to on my bus not sure if it’s the same for others
    July 15, 2020 at 7:34 am
    It is likely inside the generator hush box. You should have a breaker in the panel and a switch on the dash to control the air compressor. There is also a switch that controls the pressure and unloads the line located in the compartment under the driver’s seat. I replaced the air compressor on my 2000 only to find that it needed a capacitor.
    July 15, 2020 at 1:27 pm
    Thank you to everyone for the info, you guys are great!
