  • Low voltage
    Posted by Jeff on October 24, 2017 at 7:49 pm
    Hey gang,
    Start generator up and everything is fine. AC panel comes up inside coach all voltage and amps are within normal limits everything looks good . Then after 4 min. of running the generator transfer switch kicks out and the gen is only putting out 88 volts on each leg.
    I replaced the AVR (automatic voltage regulator) still no luck.
    Pro Tech 17.5 Gen set with 2533 hrs. Any ideas ?
    Jeff replied 9 years ago 1 Member · 0 Replies
