  • Loose bell crank bearing
    Posted by Peter on May 31, 2016 at 10:25 pm
    Had some wear on the passenger side tire it had two bushings in back on the big dog bones worn a little and bell cracking bearing a little loose replaced all and all good
    If you get air bags or ride height valves make sure you check ride height on plates of bags to make sure it’s top shelf ,
    When I got new tires after work I had a alignment done and it was out on the ride height so check those things for sure
    Anybody that puts new tires without a alignment is throwing money down the tube , I get mine aligned every time new tires are put on period unless you are just putting tires on the tag axle hope this helps out
    Peter replied 10 years, 5 months ago 1 Member · 0 Replies
