Liberty Power Problem, Part 2
As a follow up to my thread July 20 … I still have a problem.
On July 21st I had reported power seemed to be running fine in the coach, after I removed the Surge Bar. I then ordered and installed the Progressive Industries PT50X. Everything working fine, until …
On the evening of the 28th – heard loud click (like when shore power is first connected). Invertor 2 remote – indicated no “AC Input”. Seconds later – it came on … normal. No indication on EMS of any fault (E=0).
July 29th – 5am. We heard loud static, like popcorn – maybe ~8-10 seconds from the area behind the Liberty 110 panel, beside the fridge, and a few clicks. Line 2 reading as before – ~118, ~ 1.0 … no lights on any of the items powered on line 2, inverter remote 2 – no “AC Input”. The EMS did not indicate any errors – did indicate L1 = ~118, 0 – and Line 2 = ~118, 10a. Shut off all toggles on 110 panel we didn’t need. I shut off power @post.
9am – fired up Generator and all ran as perfectly. Loaded up a little with AC, from Line 1 and 2, coffee machine etc.
10am – Started power @post – let everything settle in, batteries recharge, water heat, etc. All seems normal – except … 11am – 110 Volt panel reading Line 1 = ~118, ~25a Line 2 = ~120, ~10a. EMS @post reading Line 1 = ~118, ~10a Line 2 = ~120, ~25a. Everything ran normal all day … except, opposite Line 1/line 2 readings panel, vs. post?
11pm – a few clicks near the 110 panel – Line 2 gone again as before.
So – it’s not power at the post.
It’s not the surge bar (I now have 2 good ones).
Everything seems to work fine when on Gen.
Turning power on/off @ post will likely reset – but – for how long?
Where do I go from here?
