Liberty Porch Light Switch
The Liberty porch light, little white button, was easy to replace. Mine was held in place with silicone and just took a little twisting pressure with pliers to loosen the switch and out it comes. After you recover from the cost of the switch, 26 bucks, you’re good to go.
Also, learned from Chuck that I had a switch inside the bus that also activated the light. The learning process never ends.
