LIBERTY POCKET DOOR ACTUATOR
Posted by joel on August 9, 2018 at 11:56 amleaking air. Anyone have a tutorial or hints on replacing/repairing?
1999 XLV X-6872, liberty #440Jon replied 3 years, 12 months ago 6 Members · 5 Replies -
Where is it leaking air from, the Norgren valve or a line? There is a ball valve very close by that you can close to keep any air from going to the Norgren or the door. You would just have to operate the door manually with that ball valve closed.
We found something under the bottom drawer between the bed and the pocket door wall that looks like it has something to do with the air to the pocket door. Pull the drawer out and have a look, it might be leaking there.
Hello Joel – looking for same info. If you replaced yours, can you provide the details? Thank you
No, I did not replace mine. I called Liberty for advice on how to do same and was advised that one of my shut-off valves located under a vanity sink near the norgren valve that controls the door was in the wrong position. I believe, if I understood and recall correctly, that the system may cut off air to cylinder when door is not operating. Seemed to work.
Of course, I got that info from Troy who is no longer with us. If necessary, I could probably take photo of my valve/shutoff setup.
Thank you, Joel. Troy was a good man. And, No need for the photos as have located them.
Jeff and Lindsay
91 Marathon XL
