Liberty dash lights
Posted by Cody on February 22, 2017 at 2:35 pmSome of my voltage meter gauges on my Liberty are not lighting up green such as gen gauges and house and motor. Any ideas ? They all work great though just not lit. The other dash lights work.
Ernest replied 9 years, 8 months ago 6 Members · 11 Replies -
I think the only dash gauges Liberty adds are the house and chassis voltage / ampere gauges, and the generator voltage and coolant temp gauges. On my coach they are the only gauges that have a green internal light. The balance of my dash gauges are the chassis panel that is a Prevost supplied part. I am guessing if the Liberty gauges have one or more not lit the gauge needs a new light bulb, or the electrical connection is bad.
I went and checked the green bulbs and they look good. I am wondering if it’s a fuse. Cause it’s odd it’s all the Liberty added ones not lit up.
If all of the Liberty installed lights are not lit, it is a remote possibility all are bad so you should start by checking for power at the bulbs to rule them out as the problem.
If you have the AB system in your coach check to see if they are getting power through one of those relays and if so check or replace the relay.
What does Jeff or Liberty say about potential issues?
We have a 24volt coach with Crestron. There is an icon on the driver’s Crestron screen to light up those gauges. I would have preferred for those two Liberty installed gauges to light up with the “running lights” like the rest of the dash gauges light up.
If Liberty had to add a volt/amp gauge for the chassis batteries … did Prevost provide a volt/amp gauge or gauges that Liberty removed?
The liberty guages lights are turned on by the “Dash Operator Panel” on the dashboard.
Under “Driving” Guage Lights”
Dick beat me by 1 minute.
Andre – I’m still going to get you a copy of the liberty manual I have. My copier was requiring a repair last week.
Mike -
I will go check now and let y”all know. Thanks so much y”all
Guys, I assumed Cody knows about the way to turn the dash gauge lights on. He is not a newby and I think he is starting a facebook site to offer Liberty advice.
Cody,
Did you get the dash lights working and if so what was the problem? Inquiring minds want to know.
