  • Level Low Manifold
    Posted by Fred on August 15, 2019 at 5:59 pm
    Hi PC,
    I have a five-valve level low manifold in my steer bay. The center electric coil solenoid is the ride height valve and that’s 24v but the other four solenoids are 12v. I can’t find a replacement anywhere for the 12v solenoids which I believe are made by Norgren. Does anyone know where I can get these 12v coils?
    Thank you,
    Fred
    Marius replied 7 years ago 9 Members · 9 Replies
  • 9 Replies
  • Mark
    August 15, 2019 at 8:04 pm
    Norgren??????
    I believe they have an on-line store.
  • Mark
    August 15, 2019 at 8:19 pm
    Fred
    I buy mine from prevost parts, they are always friendly and helpful and ship quick
    Glenn
    August 15, 2019 at 8:20 pm
    prevost parts are reasonable on them. I changed my center to 12V also( just pull wire from 12 V on switch or panel) there is a tiny O’ring if you pull actual selonoid off that is easy to miss –less than 1/4 od. I have a 98 last 4 numbers 6553 (unit #)
    August 15, 2019 at 9:22 pm
    You won’t get any 12 coils from Prevost, only 24. The only place to find the 12v is Liberty. Been there and done that. Maybe Jeff has them.
    August 15, 2019 at 9:34 pm
    I purchased mine from IMI Norgren in Dec 2016
    IMI Norgren link
    12v coil = pt# 54452-02 = $22ea
    24v coil = pt# 54452-03 = $16ea
    Insert pt# in the search area here on PC and it will bring up the threads I did on this subject.
  • Per
    August 16, 2019 at 8:02 am
    Under each coil is a “armature”, pt# 54462-31, $36 ea from IMI Norgren in Dec 2016
    August 16, 2019 at 10:56 am
    Don Is correct but the 24v coil Pt # 544523 I just ordered 2 of the 12v and 2 of the 24v coils 24v coils $16.82 12v coils $24.19
  • Marius
    August 16, 2019 at 11:00 am
    I tried Prevost and Liberty parts but either one has the 12v coil. Mine say made in the UK and has no part number on it. I’ll try these leads thank you all for the help.
    Fred
    August 17, 2019 at 10:02 am
    IMI Norgren (800) 514-0129
