  • LED bay lights won’t shut off.
    Posted by Archived on September 6, 2015 at 12:04 am
    Ok, I have one for ya. I installed several LED lights in my bays. The old lights were very dim and the LED’s are super bright. I used the same wiring as the old ones including the molex plugs that were on the old ones. I wired them in the worked great. Checked the door switches to make sure the would shut off. They did. I installed two more today but they would not shut off with the door switch. I took the switch off and cleaned it and made sure it would ground. Still won’t shut off the lights. So.. Just for kicks I walk around the bus open another bay where I installed lights in yesterday and the lights were on. Pushed the switch and the did not shut off. They did yesterday. The only change I made today was I turned the bus around in the barn and hooked up to my 50 amp shore power on the other wall. I can’t see that would make any difference.
    Any ideas?
    Archived replied 11 years, 2 months ago 3 Members · 5 Replies
  • Ronald
    September 6, 2015 at 7:34 am
    It sounds like you have somehow got two grounds. The second ground may be quite poor so the conventional lights previously installed might not have been on, but LEDs have such a low current draw they are remaining lit.
    If the door switch does in fact open the ground circuit, what happens if you leave the hot wire on the fixture, but remove the fixture from its installed position? If the light goes out with the ground wire disconnected the problem lies within the switch, but if you have to remove the fixture from the mounting position to make the light go out the screws might be hitting the metal chassis.
    September 6, 2015 at 1:21 pm
    The lights are half dollar size pod lights from West Marine. The base is all plastic and the light is all plastic. They have two wires that I hooked up to the plug off the original oem lights. If the lights are not hooked up correctly they will not burn (swap the wires). The screws are are 1/4 of an inch long and I have screwed them to the 3/4″ plywood floor. I am certain there is no chance of a ground to the chassis. The thing that gets me is, they did shut off with the switch but now they won’t,
    The only thing I did was, let them burn with the bay doors open and change my shore power from one side of he barn to the other.
    September 6, 2015 at 7:43 pm
    Steve when you open the bay doors sometimes the wire has rubbed through, on the top of the arms look for that I have had that happen , it can be hard to find but look closely
    September 7, 2015 at 12:09 am
    Thamks Peter,
    I will check that out. I’m getting 13.4 volts at the light with my Fluke switch pushed in or not. Some other bays work as they should some don’t…
    September 7, 2015 at 9:01 am
    This is a long shot, but on my last Liberty, I think my main through bay would turn on both side bay lights when you opened either door. So you could open the passenger side bay door and the light on the driver side would also be on. I may be reading your post wrong, if so just disregard due to CRS.
