  • Kohler Generator – Fault Code
    Posted by Loc on November 11, 2019 at 12:55 pm
    I have had this happen twice – both times starting the generator in 30 degree or colder weather when the generator is cold. It will start and run for approximately 2 minutes and then shut down and throw a OU – over volt code. I have tried resetting the ECU and re-starting the generator which will re-start but shuts down within 20 seconds and throws the code again. Any thoughts?
    Other than these two times, the generator has performed as intended.
    It is a 20KW Kohler generator in a 2008 Marathon.
    I realize the short between the driver’s seat and the start button is likely a contributing factor.
    Archived replied 6 years, 3 months ago 6 Members · 6 Replies
    November 11, 2019 at 1:34 pm
    First item to check …all the connections inside the generator mounted black control box.
    Push in connectors and crimped wire connections have a history on generators due to continuous vibration.
    November 11, 2019 at 3:41 pm
    Will do Al. Thanks.
    November 11, 2019 at 4:07 pm
    This is just a wag, but I have had to replace two voltage regulators on my Kohler, one failed allowing over-voltage and one was erratic, shutting the gen down at random times due to low voltage.
    November 11, 2019 at 5:05 pm
    Loc, have you tried starting from the gen with remote switch off? Also, assume auto start is off.
  • Harry
    November 12, 2019 at 6:47 am
    Have not Tom but I will try that. Thanks
    July 30, 2020 at 1:13 pm
    Does the vr come pre set or must it be adjusted ?
