  • Know your power source
    Posted by Greg on March 5, 2012 at 9:10 pm
    In July I added an 12 volt Aux Compressor to my coach because I had not chase down all my air leaks and I wanted to kee[ my tags from dumping when the pressure got low. I Aug I replaced a set of 6 year old coach batteries that had been holding up fine for years. Last night getting ready to go for dinner I noticed the coach batteries at 21.8 volts. I turned the key to see if it would start, just click, click, click. “What’s going on I just replaced them for the same symptom. I turned off the 24 and 12 volts switches engine compartment hoping in the morning I would have enough volts to start in the morning, no luck on this. At six in the morning I started thinking I didn’t hear the “fog horn” noise I posted about. So I got up and turned on the Webasto SMX controls for heat, 15 minutes later I noticed I didn’t hear the Webasto making any noises either. Then Bingo my Friend it hit me that the Aux compressor and Webasto are powered from the coach batteries and draining my coach batteries. The Webasto was not a big problem but the Aux Compressor going off three times a day was hard on the batteries. I will differently rewire the Aux compressor to the house batteries since it is only needed while parked.
    Larry & Diane replied 14 years, 8 months ago 3 Members · 2 Replies
    March 6, 2012 at 6:40 am
    Greg,
    What 12/24 compressor do you have that is robust enough to handle the aux needs? All of mine have been 120v.
    March 6, 2012 at 10:44 pm
    Tom will get back to you on that. It is something I found in a wrecking yard for RV, but it 12volts and has a solenoid that relieves the head pressure when it turns off. I couldn’t find my pictures of the setup.
