Knorr-Bremse Brakes
Posted by Archived on May 4, 2022 at 5:14 pmAfter some research, pretty sure I have Knorr-Bremse brakes instead of the Meritor system.
Anyone have any experience with these? Not even seeing a grease fitting on them.
DON replied 4 years, 6 months ago 7 Members · 10 Replies -
I don’t recognize any of that?
The 5 tag axle diesel pushers I’ve owned, yr models 1995 to 2002, all had Meritor.
Don-
I did some sleuthing on the net, I believe they are KNORR-BREMSE. My luck, after I downloaded the two awesome manuals you linked and printed out your specific directions and took it under the bus with me. And…. I couldn’t find any of the items mentioned. I don’t even see how they are lubed, didn’t see a grease fitting. So I guess I can rule out over greasing as the cause of the pad drag.
Luc
Those are indeed Knorr-Bremse. They have a boot or seal on the slide pin that deteriorates over time allowing dirt and moisture on the slide pins, causing dragging or lock up.
Rebuilding them is not all that hard. The rebuild kit includes two different types of grease and explains where to use them. Pay attention to the instructions.
My Prevost manuals have the Knorr-Bremse manual as part of the booklet. There are great instructions (and pictures too??). Also found online how to videos too.
Found various articles stating the only real issues with the Knorr-Bremen is the slide pins dragging or locking up from dirt or rust and normally happens on vehicles not frequently used. Biggest problem was noted as vehicle (wheels) being washed then stored (not driven afterwards) allowing rust to form on the slide pins.
When I rebuilt mine they were in need but still in working order.
Chuck
Chuck-
Thanks for the good information. I did have a pad drag situation on the left front wheel. I was wondering if the brakes were over greased at the dealership, but I couldn’t even see a grease fitting on the caliper.
Do they have grease fittings, or are they just lubricated by hand with the specialized grease you mention when doing a rebuild or inspection?
Lubricated by hand during the rebuild.
YouTube the brakes. There are various informational Youtube videos.
Chuck
Ok that makes sense.
So I guess I can rule out the “over greasing” possibility for the pad drag.
Jeff and Lindsay
91 Marathon XL -
Luc,
Have you seen Gil Johnson’s Youtube video on knorr Bremse brakes?
Jeff and Lindsay
91 Marathon XL -
Jeff:
Forgot above Gil’s Video. Great catch/input.
Chuck
Hey Jeff-
I just watched it. Good stuff.
Thanks for the heads up!
Glad to point you to it. Gil’s videos are very informative. Hope you can get it sorted out. Jeff
