  • Keyless remote
    Posted by Vince on August 17, 2013 at 2:29 pm
    Hi I have a 2006 H3-45 VIP. I’m looking for the proper pocedure for programing a new keyless remote or fob. If anyone knows i sure would appreciate the help. Thanks
    Archived replied 12 years, 8 months ago 3 Members · 5 Replies
    August 17, 2013 at 4:00 pm
    you might try this
    Programming a personal
    entry code
    The factory set code cannot be reprogrammed but you can create
    your own 5
    �digit personal entry code.
    When pressing the controls on the keypad, press the middle of the controls to
    ensure a good activation.
    Up to three personal entry codes may be programmed to the vehicle. To
    create your own personal entry code:
    • 1. Enter the factory set code.
    • 2. Within five seconds press the 1
      � 2 on the keypad.
    • 3. Enter your personal 5-digit
      code. Each number must be entered within five seconds of each other.
    • 4. Press 1 �
      2, 3
      � 4 or 5 �
      6 to indicate which of the three personal entry code positions you wish to
      use.
    • 5. The doors will again lock then
      unlock to confirm that your personal key code has been programmed to the
      module.
    Tips:
    • Do not set a code that uses five
      of the same number.
    • Do not use five numbers in
      sequential order.
    • The factory set code will work
      even if you have set your own personal code.
    • If you program a code to a
      position that already contains a set code, the previously-set code will be
      erased.
    Erasing personal code
    • 1. Enter the factory set 5�digit
      code.
    • 2. Within five seconds, press the
      1
      � 2 on the keypad and release.
    • 3. Press and hold the 1 �
      2 for two seconds. This must be done within five seconds of completing
      Step 2.
    All personal codes are now erased and only the factory set 5�digit code will work.
    Setting FOB to work with
    your vehicle
    1. Sit in car, doors closed.
    Electronically unlock all doors using the power door unlock switch on the
    driver’s door.
    2. Insert key into ignition
    switch and turn from OFF to ON 8 times within 10 seconds with the 8th time
    ending in the ON position. (5 times on some models)
    3. The doors should lock and
    unlock by themselves to signal programming mode.
    4. Using your remote: lock the
    doors.
    August 17, 2013 at 5:37 pm
    Vince,
    Just a comment, if Greg’s procedure does not work contact the converter. I believe the converters install aftermarket alarm systems and they might have the fob as part of the system.
    A word of caution. Some alarm systems controlled by the key fob not only lock and unlock doors and bays, they also disable the engine. proceed with caution because where and how the engine is disabled is probably converter specific and you really want to know how to reverse that if you accidently alarm and disable.
    August 17, 2013 at 8:01 pm
    One more thing…Prevost told me in JAX a couple of weeks ago, that there is more than one way to program the remotes. Mine worked with the 8 cycles of the ignition switch, but I think there is one that used 5 or 6 cycles. You may want to check with Prevost if you have trouble getting it to work.
    August 18, 2013 at 7:16 am
    Here’s what we did for our 2006 Marathon XLII:
    1. Close all doors, then open your driver side door and press the Unlock button on the drivers door while it is open.
    2. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. The door locks will lock and unlock to confirm that you have entered programming mode(Off is the position where you can remove your key, RUN is the position just shy of starting your car. If the door locks do not cycle you should try it again but faster. If they still do not cycle, your vehicle may not have keyless entry)
    3. Within 8 seconds press any button on the first keyless remote to be programmed. Door locks will cycle to confirm programming. If you only have one remote then skip to step 5.
    4. Within 8 seconds, press any button on the second keyless remote. Door locks will cycle again to confirm programming. Repeat step 4. for all other remotes.
    5. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
    If you look up the model of your key fob online, you should be able to get specific instructions for that fob.
    March 5, 2014 at 1:25 pm
    I did the same thing for our 2005 Country Coach. It took 8 on-off cycles and programmed three remotes. Thanks for the info!
