  • Key switch / air bag belt tensioner
    Posted by David on June 17, 2021 at 9:53 pm
    I am now having a unusual problem . When I turn off my key switch the air in my belt tensioners will lose air in about 15 mins . when I turn the key back on the air bags will inflate ( as long as I have air in the main tanks ) . I would like to add I have been driving in some heavy rain the last few times I have been out …
    Archived replied 5 years, 4 months ago 2 Members · 1 Reply
  • 1 Reply
    June 18, 2021 at 7:35 am
    The belt tensioner system has to have a check valve to prevent air in the small bellows from leaking back into the bus system. But having said that based on your comment that the system re-pressurizes when you turn the key back on suggests that is not likely the problem.
    The air into the system goes through a pressure regulator which has to control the pressure to XX PSI. I cannot remember the exact pressure. It also goes through a valve that when open inflates the bellows, but when closed exhausts the air in the bellows system. Both the regulator and valve have a tendency to leak.
    But with the various fittings and the small bellows there are multiple potential leak points. Soapy water will help you identify where you are losing pressure.
