  • Jun air model works with our coaches
    Posted by Jim on March 10, 2013 at 10:42 pm
    Anyone know what model jun air works good with our coaches 2000 h3. Cc. Thanks Jim
    Archived replied 13 years, 8 months ago 5 Members · 14 Replies
  • 14 Replies
    March 11, 2013 at 7:39 am
    Jim,
    Who’s your Converter? That may help with answers.
  • Jim
    March 11, 2013 at 12:51 pm
    Sorry its a 2000 h3-45 country coach thanks for your help
  • Jim
    March 11, 2013 at 1:37 pm
    Jim.
    I don’t know what HP compressor you need but using this as an example I see some things you need to consider.
    http://www.grainger.com/Grainger/GAST-Piston-Air-Compressor-2Z867?Pid=search
    The compressor should be oilless. It should be capable of the pressure you need. I picked that one because it is not only rated at 100 PSI, but is rated at that pressure for continuous duty. The duty cycle is important.
    One of my coaches had the compressor in a box with some accoustic foam used to deaden the sound. That was a good thing. If you don’t have the sound deadening you should consider either a very quiet compressor or an enclosure.
    I know guys do it, but I would never use a compressor with its own tank unless the system had a protection valve to prevent a loss of air from a failed tank from impacting the coach systems.
    I don’t think there is any correct answer to your question because you have to decide what specs you seek in a compressor and that ranges from pressure, voltage, duty cycle, HP, noise level, and quality. There are really cheap compressors out there with good specs, but they may not have the durability you really need.
    March 11, 2013 at 5:50 pm
    Thanks Jon I am amazed on how knowledgeable you are on these coaches. I was looking at the jun air because they are so quiet. I have a small panache compressor but its very noise. But maybe building a hush box would be a good answer. I read one of the threads about using jun air but I have no idea about which model. Thanks for your help I enjoy and learn a lot from your articles. Jim
    March 11, 2013 at 6:32 pm
    Jim,
    Is the compressor mounted without any noise dampening hardware ?
  • Georges
    March 11, 2013 at 6:35 pm
    I make stuff up.
    yes it’s just setting in the bay with one stud holding it down
    March 11, 2013 at 8:57 pm
    The compressor should have rubber
    isolators and be securely bolted to the floor. All of the compressors
    I have had have been held in place with 4 bolts.
    March 11, 2013 at 9:10 pm
    Not only should they be isolation mounted they should have a noise reduction air intake filter. You might be surprised how much these reduce the noise.
  • Jeff
    March 11, 2013 at 9:44 pm
    I have a JUNair it is an oil bath type looks like a alunium case works great you can not hear it run if you are holding it , i belive they were desighined for a dentist office mine is 110 volt,,, the entire unit is srounded in oil
    March 11, 2013 at 10:09 pm
    March 11, 2013 at 10:11 pm
  • Terry
    March 12, 2013 at 7:03 pm
    Yes that would be my new baby
    March 18, 2013 at 9:59 pm
    sounds like you know the coach would you email me your phone number so I can call you tuffytc1@yahoo.com Thanks. Jim
