  • Jake Brake Issues
    Posted by Derrick on October 9, 2017 at 6:17 pm
    Hi Friends, I have a ongoing problem I can’t seem to get solved. My second stage Jake Break has not worked sense I bought my 05 Marathon in May. Its been to Prevost Mira Loma several times. Finally everything works except the secondary Jake. A month ago they told me everything worked all the way to the computer, and it must be in the engine. We replaced the harness and the solenoids (fairly big job) it did not help. We tested the old solenoids and the new ones in the bus and they both worked fine. I returned to PrevostMira Loma and ask they try again. This time they said it was not programmed from the factory to have 2. With some research we dispelled that nonsense. They tried again. That came back with the Detroit computer didn’t get programmed for a second Jake. I’m hoping to get it to a Detroit dealer to look and see if thats the case and maybe reprogramme that but no luck finding anyone who want to work on this.
    Any comments will be appreciated
    Thanks in advance
    Derrick Sandwick
    Archived replied 9 years, 1 month ago 6 Members · 7 Replies
  • 7 Replies
  • David
    October 9, 2017 at 9:03 pm
    With the same symptom, that is first speed works but second speed not, the fix was simply to replace the switch on the dash. From memory it was 25 or 30 dollars from Prevost Parts. I’m one of the guys who switch it on each time it’s needed rather than leaving it on all the time. So the contacts probably said ENOUGH!
  • Rudy
    October 10, 2017 at 6:12 am
    This is just a general comment that might apply to all Jake brake equipped coaches.
    Prevost has two terminals in the rear electric box that supply power to the Jake brake solenoid valves that are under the engine valve cover. There is a way to help isolate the problem when the Jake is not functioning or is only partially functioning.
    The terminals are listed on the chart showing the electric box. If the engine is idling, and a jumper feeds power to each terminal one at a time you will hear the engine lug down. What you are doing is powering the solenoids directly and verifying they are doing what they are supposed to do.
    If the engine does not lug down when power is applied to the Jake terminals then there could be a problem with the solenoids or the wiring to the solenoids. If the engine does respond by lugging down the reason the Jakes are not working is elsewhere. If a mechanic wants to change the solenoids in the engine without testing as described above he is just guessing and spending your money. BTW, the problem if it appears to be in the engine can be as simple as a disconnected terminal or broken wire.
  • Dan
    October 10, 2017 at 8:03 am
    Derrick,
    I returned your email regarding your Jake brake. We discussed this with Bill Jensen at the seminar just to make sure we were correct in telling you that you do in fact have a 2 stage Jake. Your button should have 3 positions, off, 1 & 2. Position 1 uses 4 cylinders and position 2 uses 6 cylinders.
    You’ll just have to find someone who can diagnose the problem as Jon pointed out.
  • Dan
    October 10, 2017 at 8:40 am
    I just had work done at the DD/Allison dealer in Ocala, Florida. Part of the work was the diagnosis and repair of my non-functioning Jake brake. The techs seemed to have extensive knowledge about Jake brakes. They did a good job, and they do not seem to dislike working on Prevosts.
    I understand that you are on the other side of the country, but if you head this way, I recommend them.
    October 10, 2017 at 10:59 am
    Thanks Dan, We changed it at the same time we changed the solenoids. I taking it to another Detroit guy today, we’ll see.
    Thanks again
    Derrick
    October 10, 2017 at 11:02 am
    Thanks Jon, learned this the hard way, changed solenoids and the old ones were fine. Going to another Detroit Dealer for computer program work today.
    Thanks Jon
    Derrick
    October 10, 2017 at 11:05 am
    Thanks Colt, I wish I was heading you way, maybe January.. Thanks again.
    Derrick
