Inversion Valve Replacement
I replaced the TR-2 Inversion Valve just because it looked like it had not ever been replaced.It could be a source of air leak from Primary air tank (rear). The inversion ia a always open valve from tank to supply port of valve always open to delivery port that has 2 lines going to R-12 valves to control port for tag brakes ,on both sides. So what it does is air passes through Inversion valve always open port to R-12 valves so when you apply brakes tag brakes work, When you lift tag air opens Inversion valve from supply air to control port on inversion valve to 3 port Norgren valves lift tag and keeps tag brakes from coming on .
