  • inside door handle mechanism issue
    Posted by john on November 8, 2022 at 10:32 pm
    Part 283851 shown below. prevost shows no stock. the spring is broken. Even if I drilled out the assembly rivets, I doubt I could match up the spring. Any leads on the manufacturer or other vehicles that use this?
    Marvin replied 4 years ago 6 Members · 5 Replies
    November 8, 2022 at 11:44 pm
    November 9, 2022 at 5:12 am
    I have purchased parts from Visone in the past and been satisfied. They may have what you need.
    https://rvexteriorbodypanels.visonerv.com/cgi-bin/f/prevost-mci-busparts.pl
    November 9, 2022 at 8:03 pm
    ch out ford truck inside door handle from 80’s thru mid 90’s. I’ll ck tomorrow if I have one in treasure chest(pile of door parts) Will post if I do. Bob
  • Clay
    November 10, 2022 at 10:02 am
    with your suggestion I just started looking at ebay door handle control and found 1968 -72 gm. they are close. whats interesting is Prevost shows the part with splines like the gm part but mine has a square interface. also somebody welded on a piece for the slot- you can see that in the picture.
    Looked at Ford trucks on LMC and ebay but did not yet find close match.
  • Marvin
    November 10, 2022 at 6:42 pm
    could not find box of door parts today. Will continue to look. prevost took alot of other mfg parts and modified to their use. with only slight changes. My opinion only.
