  • Inoperative Analog Water Temp Gauge
    Posted by Eric on January 5, 2019 at 4:20 pm
    Need help diagnosing my dash analog water temp gauge. On drive back from FLA, the gauge slowly went from correctly reading to a bouncy reading. The needle bounce severity increased with time and was affected each time the bus hit a pothole. The bouncing needle trended towards zero, and after an hour, the needle went to zero with no further movement. During the trip, I used RV Dash, and the DDEC supplied readings showed the expected water (coolant) temps of approx. 200 deg F the entire time, with no associated bouncing as noted on the analog gauge. I neglected to observe the engine compartment analog gauge after parking.
    My question is, what is most likely the problem – bad analog gauge or defective sending unit. Trouble shooting suggestions.
    DON replied 7 years, 10 months ago 2 Members · 1 Reply
  • 1 Reply
    January 5, 2019 at 7:54 pm
    Eric, Start with checking grounds and connections
