  • How to remove rear skirts
    Posted by Pat on July 9, 2021 at 10:57 pm
    How does one remove the rear wheel skirts on a H3-45.
    Jim/Chris replied 5 years, 4 months ago 4 Members · 3 Replies
    July 10, 2021 at 7:05 am
    Are you asking how to remove the fenders?
  • Glenn
    July 10, 2021 at 9:06 am
    Unless something has changed,
    There are two pins, one on each bottom corner near the tires. There is a small level that you push/pull to release the pin.
    In the center section there are either thumb screws or rubber retention bungees hooding the center section.
    Once everything is release it should drop straight down. So have someone hold the center while another releases everything so it doesn’t drop to the ground and chip your paint.
  • Unknown Member
    July 10, 2021 at 5:45 pm
    Thanks now the fun starts.
    PJ
