  • How many volts should it read on a full charge?
    Posted by Dick on April 18, 2016 at 11:56 pm
    I noticed that after driving the coach for 2.5 hours and drawing very little if any 120 volt power during that time, immeidately after shutting the coach down the inverter remotes read out that the house batteries are at 25volts (see the picture attached).
    Then after having the coach on shore power for 24 hours and shutting off the shore power, the inverter remotes show 25 volts too.
    Is this normal? I am presuming after 2.5 hours of interstate driving the house batteries should be fully charged. Same thing having the coach on shore power for 24 hours and in both cases very little 120volt draw. Is 24 volts fully charged?
    Our coach batteries are Lifelines which were installed in April or May of 2014.
    What do other Liberty Elegant Lady (24 volt) coach owners see on their original Heart Freedom interverters?
    Archived replied 10 years, 6 months ago 2 Members · 2 Replies
    April 19, 2016 at 7:00 am
    A 24 volt system is 100% charged at 25.2 volts. This is at rest with no charge source active.
    April 19, 2016 at 9:00 am
    Individual resting voltage should be 12.8 or 25.6 if you disconnected the batteries and checked. Like Mikee said, 25.2 should be good. Check the batteries with a meter if you want to verify the remote readings.
