  • How do you test your battery equalizer?
    Posted by Archived on December 14, 2014 at 1:00 am
    Two of 4 of my chassis batteries are toast and so I am replacing all four. I have been told that since two failed it could be an indicator of my battery equalizer failing. Is there a test for this? Also I see equalizers on ebay from 350 to 550 bucks. Amps ranges from 80 to 100. Can anybody tell me what amps I need?
    Archived replied 11 years, 11 months ago 1 Member · 4 Replies
    December 14, 2014 at 1:49 am
    Seeing your sign location as Bend OR. your just a stones throw from Marathon factory.
    Give Leon a call at Coberg …as he can probably pull up the build sheet to give you information on what you have installed.
    Leon will ask for your build number.
    December 14, 2014 at 7:20 am
    The Vanner web site has documentation on all their products, including the equalizer and the monitor. They outline how to test them.
    The simple way (although not a complete check) is to measure voltage at the 12 and 24 volt terminals. If the 12 volt side reads 1/2 of the 24 volt side within 1/2 volt the equalizer is within spec.
    If your coach has a Vanner monitor an equalizer failure would have caused the monitor to give you an indication on the dash of a high or low battery voltage condition or a battery imbalance.
    December 14, 2014 at 8:25 am
    You’ll need a 100 amp Vanner, my Marathon has 2.
    Note – You don’t have a Sure Power do you?
    December 14, 2014 at 8:29 am
    I think that vintage coach started life with 2 50 amp equalizers. They might have been replaced with a single 100 amp. But regardless I think the original Vanner equalizers used around that time did not have a fuse or circuit breaker, but later models did have one located on the bottom. If there is any question about if they are working that is the first thing to check.
