Holding Tank Material
Correct me if I’m wrong, but none of our coaches were produced from the same mold. They are “custom” built, “built to order”.
With that belief, I do know that our particular coach has 3 separate holding tanks, with 3 separate gauging systems. There is NOT an interconnect for the gray and black tanks.
The fresh and gray tanks are made of 1/4′ thick translucent plastic. At this time there is nothing wrong with the plastic tanks at all. I can’t think of anything that might go wrong with them in the future.
The black tank looks like it is made of galvanized steel but I could be wrong. It might be aluminum, based on the welds I see. I pulled a 2″ rubber cap off and looked inside and can see some corrosion. Its just a matter of time.
Here where I live, there is a company that will build custom plastic tanks to spec for anybody for not much $. If my metal tank fails while I own it I’ll be replacing it with a plactic tank unless somebody can convience me to do otherwise.
Educate Me. Thoughts?
