  • Help! Dash Light Dimmer Part
    Posted by Liam on April 3, 2014 at 12:59 pm
    Need help. My bus was manufactured in June 1991 and finished in 1992 by CC.
    This dashboard rheostat sits in a box built by CC that houses the wheels-up, pull-to-park and this switch. The switch has part number 2173333 stamped on it but that is not a Prevost part.
    3 red wires and one white wire attach to this switch. You pull it up to turn-on the dash lights and rotate to dim. Would love help finding a replacement part or at least a wiring diagram so I can retrofit something.
    Wires 24, 24F & 24G + one white wire connect to it.
    Thanks!
    Archived replied 12 years, 7 months ago 5 Members · 4 Replies
    April 3, 2014 at 4:42 pm
    Liam
    Is it 12v or 24v? if 12v a Ford Pickup light switch from the 1970’s and 80’s.
    My bus as build the same time as yours, what is your vin# mine is M1838?
    Greg
  • Jim
    April 4, 2014 at 3:13 pm
    Received a PM from Gil with the link below. The part looks identical to my switch so I ordered one today. I did confirm CC installed these and not Prevost. Can’t wait to see the actual circuit diagram if it comes with one. Thanks for the help. My VIN is M1001912 and I am CC #60160
    http://www.summitracing.com/search/part-type/headlight-switches
  • Robert
    April 4, 2014 at 9:24 pm
    Liam I just got back from the Portland Auto Swap Meet, they had lots of them at the booths ranging anywhere from 5 dollars to 20 new and used. they looked likea GM auto part.
    Greg
    April 8, 2014 at 8:11 pm
    Liam,
    I was told the switch in my 1990/1991 was from that years Buick headlight switch. Don’t know which model Buick.
