  • Heart Interface Freedom Remote
    Posted by Michael on August 12, 2018 at 11:58 am
    Does anyone know a source where I can find a Heart Interface Remote panel like the one attached?
    Chuck replied 8 years, 2 months ago 7 Members · 7 Replies
  • 7 Replies
  • Tom
    August 12, 2018 at 12:56 pm
    Try Jeff at ETLC.
    A lot of the Freedom inverters have been swapped out for Magnum and I suspect there are quite a few of the remotes available.
    August 12, 2018 at 2:38 pm
    Contact information please.
  • Rocky And Tonya
    August 12, 2018 at 3:31 pm
    Jeff Rowe
    (423) 884-6008 jeff.etlc@gmail.com
    Vonore, TN just SW of Knoxville
    If you own a Prevost, Jeff’s number needs to be in your speed dial. Don’t leave home without it.
    August 13, 2018 at 5:32 am
    I do have them…have you tried swapping the remotes as in the picture it looks like one shows ac input and the other doesnt, so I assume that is why you are looking for a remote?
  • Chuck
    August 13, 2018 at 10:01 am
    Yes, that is why I am looking for a replacement. No, I have not swapped the other one. I will give it a try.
  • Jacky
    August 13, 2018 at 10:59 am
    Thanks to Jeff’s suggestion, I swapped the A and B panel leads and found the problem followed the lead. Conclusion: nothing wrong with the remote panel. I then checked the “A” inverter and found the 30amp “Charger” fuse had tripped. I reset the fuse and things are now back to normal. I will keep an eye on that fuse in case it trips again. That may mean a faulty inverter.
    I did have some electrical-related work done on the coach last week which may have caused the fuse to trip.
    Thank you Dick for referring me to Jeff. Thanks Jeff for setting me in the right direction.
    Love this community! Answers abound!
    August 13, 2018 at 11:10 am
    I just threw 2 away. Upgrade to this one, Much better same thing just easier and more options (upgrade)
