HEADHUNTER TOILET WOES
Well, we finally have taken some time off and trying to enjoy our bus. Day one was spent replacing the Mach 5 water pump. Now, the Headhunter toilet will not flush. Nothing happens when the flush button is depressed. I suspected that I had air in the water system caused by the pump replacement, but clearing all air from the water lines has not helped.
I have read about a manual flush feature, but I cannot locate the “white lever” for manual flushing.I have also read about bypassing the solenoid, but I am unsure how to do it. I have not been able to locate the solenoid. The Headhunter toilet was a retrofit before we bought the bus.
I have been able to remove from the rear of the toilet all wiring and the timer box.
I have verified 12 volt power.
We really need to flush the toilet somehow, even if we cannot restore normal operation.
Any ideas for restoring function, bypassing the solenoid, or manually flushing?
