Headhunter Toilet – Intermittent Long Flushes
I thought I had a problem with the flush timer, sometimes the
toilet would do a long flush and other times work just fine. Turns
out, the flush valve diaphragm has a really tiny hole that I assume
relieves some pressure and must not get clogged with debris.. Sure
enough, the old diaphragm accumulated some crud and was plugged and
showed it’s age. Replaced the diaphragm and spring and all is well.
The folks at Headhunter are very helpful with troubleshooting.Here’s a picture of the valve and diaphragm:
I wasn’t done wire tying the wires back in place in case Jon picks on me..
